1991 fatboy starting HELP
Old 07-03-2008, 12:06 AM
cdnrider's Avatar
cdnrider
cdnrider is offline
1st Gear
Default 1991 fatboy starting HELP
Hi ,it sounds like a common problem in a few models. I just bought a 1991 Fatboy&nbsp\\;\\\\\\; from the original owner&nbsp\\;\\\\\\; with&nbsp\\;\\\\\\; just over 10,000&nbsp\\;\\\\\\; original miles. when the bike was loaded up it apparently started right up. After we unloaded it , the starter turned over with lots of power , but wouldn't fire.
The cables were all tight , a new&nbsp\\;\\\\\\; battery&nbsp\\;\\\\\\; charged right up.&nbsp\\;\\\\\\; Now it&nbsp\\;\\\\\\; just clicks. There is a recall on the starter relay ,&nbsp\\;\\\\\\; and 30amp breaker .&nbsp\\;\\\\\\; so I'm getting that looked.
what else could it be? very frustrated........&nbsp\\;\\\\\\; bike is mint.......&nbsp\\;\\\\\\; and I'm missing&nbsp\\;\\\\\\; ALOT&nbsp\\;\\\\\\; of&nbsp\\;\\\\\\; riding
HELP&nbsp\\;\\\\\\; please !!!
Old 07-03-2008, 09:30 AM
mjmangus's Avatar
mjmangus
mjmangus is offline
Default RE: 1991 fatboy starting HELP
Check your charging system.&nbsp\\; If you do a search I'm sure you'll be able to find detailed instructions from one of the members.
Old 07-03-2008, 01:22 PM
92Fatty's Avatar
92Fatty
92Fatty is offline
Can you jump it off? What is the voltage at the battery when trying to crank it over? Did you check for spark? Wouldn't fire could be fuel or ignition. Not trying to be an a$hole did you have the gas turned on? Fuel or spark need to figure which is not present. Kent
king1pin1
07-06-2019 08:52 PM
billyg1
08-23-2015 08:13 AM
bobbersoul
10-04-2012 08:52 PM
cdnrider
EVO
07-04-2008 08:02 PM
ironorange
09-18-2006 01:38 AM
Quick Reply: 1991 fatboy starting HELP
