Help with New tank and fender replacement on 05 Fatboy
Just received my new tank and fenders for the Fatboy. \\; The front \\; and rear fender don't seem to be that big a deal to change out. \\; How hard is the gas tank to change, haven't had one off before so any info will be a big help. \\; Anything \\; I need to replace before mounting the new tank? \\; I plan on using all the old mounting hardware, will that be ok. \\; Thanks for any help I can get, I have got to get it back together so it doesn't interfer with my weekend trip.
RE: Help with New tank and fender replacement on 05 Fatboy
Did the same thing recently on my Road King. \\; Removing the fuel pump/level assembly can be tricky. \\; You'll definitely want a shop manual for assistance. \\; And an extra set of hands will help to keep you from scratching anything. \\; You will need to remove the pins from the fuel gauge plug in order to remove it. \\; You should be able to re-use all the original mounting hardware. \\; Go slow and be careful. \\; Took me about a day.
