Heartland kit question
RE: Heartland kit question
My 240/250 Avon Venom just fits. The belt clearance is the concern,
it may be possible to use some small spacers on the wheel belt pulley
 \\;to offset it enough without causing a problem with the transmision end.
 \\;Carefull measurements should be completed Select the 260 you want
 \\;to use and get all the numbers, then compare to current tire. If you
 \\;find that this works please let me know as when I wear out my tire
I would go up a size as well.
Crossbones Heartland
That crossbones with the heartland kit looks insane. It's without a doubt the sickest crossbones I've seen yet! Do you have anymore photos of it.
I've been looking to put a 250 kit on my crossbones but I haven't seen the rear fender hug the tyre like that. Everyone's told me I won't be able to achieve that look. Any help or photos you could post would be greatly appreciated. Again... Well done. Two big thumbs up!
RoadKingGibson
Wheels/Tires
05-10-2012 11:53 PM
RoadKingGibson
05-02-2012 09:38 PM
