Damn oil filter
RE: Damn oil filter
Here's the answer. \\; Next time you change oil, take your new filter to the Car Quest, or NAPA, or whatever parts place. \\; Tell them you want an end cap filter remover to fit that filter with a 3/8" drive. \\; They'll have it. \\; They're about $4. \\; Then just use a 3/8" rachet with a 6-8 inch extension, and it's a snap. \\; Problem solved. \\; The strap thing is a PITA. \\; CCRyder
RE: Damn oil filter
if you get a oil filter from K&\\;N it has a bolt welded to the end so you can just use a wrench...it looks like this
http://www.knfilters.com/search/prod...x?Prod=KN-171C
RE: Damn oil filter
Cool! PF 47 is GM small filter they have used for years, thanks for the tips! I do have a set of KD filter wrenches but the side wall is too big, won't fit between the filter and the engine crankcase.
ORIGINAL: deadman77
I use the one that fits the AC Delco PF 47 filter on my car.
Works just fine.
MikeM
Works just fine.
MikeM
RE: Damn oil filter
ORIGINAL: Archer1968
if you get a oil filter from K&\\;\\\\\\;N it has a bolt welded to the end so you can just use a wrench...it looks like this
RE: Damn oil filter
Does KN make chrome filter housing?
The welded nut is great!
ORIGINAL: Rocker C
Yes. Just buy the K&\\\\\\;N filter and dont bother with the Harley junk.
if you get a oil filter from K&\\\\\\;\\\\\\\\\\\\\\;N it has a bolt welded to the end so you can just use a wrench...it looks like this
