Bleeding front brake and brake fluid
When swapping my front master cylinder is it necessary to completely bleed the line if I am just going to unhook the brake line from the old master cylinder and put in on the new one? \\; Also, I have the same bottle of DOT 4 brake fluid I used two years ago when I added the new brake line, is it still good or should I buy a new bottle? \\;
RE: Bleeding front brake and brake fluid
if you have trouble bleeding brakes you can take a pump type oil can that is clean inside fill it with brake fliud,attach a rubber hose to oil can.then open bleeder in caliper and push clean brake fliud up into the master cyl.this will push the air out of the line.i would also get a new bottle of fliud
I dont think i would do the pump method with dot 4. if any is left in your line and it sprays it can get on your paint. dot 4 will eat your paint. I would change to dot 5 works fine and wont hurt your paint. just flush system and fil with dot 5.
ORIGINAL: custom roadglide
thanks guys, I was leaning towards getting a new bottle anyway, it's cheap insurance and peace of mind. \\; Changing to DOT 5 won't damage the seals or anything in my calipers?
What about DOT 4 residue in the line mixing with the DOT 5? \\;
Thanks for the reccomendations on the tools, I will look into that. \\; I'm sure this won't be the last time I bleed the brakes. \\; I know \\;I will be swapping out my rear brake line for a SS braided one and I will eventually go to 16" apes which will require changing front brake lines again, plus I can add another tool to the box. \\;
