07 fatboy exhaust?
08-04-2008, 01:09 AM
07 fatboy exhaust?
got about 1000 miles ,and notice the pipes are turning blue,is this normal?
08-04-2008, 01:14 AM
RE: 07 fatboy exhaust?
Stock pipe? Aftermarket pipe? Do you mean the pipes turn blue or the heat shields? Stock air cleaner? It could be an A/F ratio issue.
08-04-2008, 01:17 AM
stock everything,the piped not the covers,mainly by the heads
08-04-2008, 01:23 AM
I do get blue right at the header pipes, I don't too worry. I also heard the 07 with the O2 sensors runs a bit lean, it could be running a bit hot. You got to know how hot it is right there, little is normal.
08-04-2008, 06:38 AM
very common, I would guess if you removed those shields you would see the entire pipe blue. completely normal. changing those stock pipes to aftermarket pipes and new a/f plus some type of race tuner will take care of that heat issue
08-04-2008, 07:38 AM
you need a fuel management even with stock due to what the EPA did to the Afr
HoldFast2012
04-06-2013 10:16 AM
Rubbit
02-02-2011 12:01 PM
nacomedian
General Topics/Tech Tips
09-13-2008 01:07 AM
hoosierdaddy
Exhaust System Topics
02-20-2008 07:23 PM
ndotken
09-18-2006 08:37 PM
07 ,
2007 ,
blue ,
boy ,
buy ,
changing ,
exhaust ,
fat ,
fatboy ,
harley ,
hd ,
hooker ,
pipes ,
turn ,
turning
