Headlight dimmed...
Headlight dimmed...
I had replaced the OEM headlight bulb and had it running for about a year now! Last 2 months was having a dimming of the bulb, then really bright. High beam indicator on dash would come on also. This would come and go! It looked like I had a short. Had replaced the bars,controls, and extended the wiring earlier. Thought that might be the problem area...
Bulb finally burned out, and when I took apart the assembly to replace it...The harness connector that the bulb plugs into was melted
I replaced the connector and put the OEM bulb back in, and it seems o.k.
Anybody run into any issues with the Sylvania Silver Stars?? Same rated voltage/watts...but must run a-lot hotter!!
Headlight connector melted
I had a similar problem and solved it by putting in a ceramic connector from Eastern Beaver (Yeah I know strange name but good parts and info therein)
The problem was and is always at the connector. Sometimes the wires will get hot if they are very old or degraded, but that problem can be fixed by adding the relays HD should have put in at the factory if the new connector just moves the problem to the wire.
Eastern beaver also has a discussion on headlights that is well worth the read.
http://easternbeaver.com/Main/Elec__...onnectors.html
