Typhoon wheels for my Fatboy
I want to install a set of Typhoon style wheels on the Fatboy ( I LOVE this style wheel!!). I have a 2007 version. They only make the rear wheel for 2008 Softails ( I am assuming I can by the 2008 25mm rear axle and install it, and the belt/rear brake rotor offsets should match?? I know the rim dimensions are the same as stock), and Id like to use a front rim that is intended for a Dyna (19 inch version) so I can retain my front fender. Is this as simple as buying a new axle (will it fit inside the 2007 FL 25mm axle forks)?? I have a friend that has volunteered to make me some custom spacers should I need them to line up the front wheel, and Im also unsure as to front rotor offset differences?? Any input will help thanks!!
sagebrush1976
01-26-2016 09:00 PM
traveler
12-10-2006 01:03 AM
