Heritage-harsh ride
Heritage-harsh ride
I have a 2000 heritage with 10,000 miles.I have it about six months and put 1500 miles on it.I had been riding early 80's goldwing and the harley ride is much harsher.
Is this normal or is there something I can do.
The bike had been sitting for about 9 months when I got it.Should I change the fork oil and where can I get the spanner wrench to adjust the rear suspension?
Jim
Jim
Look under your bike and you should be able to see if your shocks are set to the soft or firm position. You will be looking at the forward end of the shocks, between the retention nut and where the shocks mount. If you see 4 threads on each shock shaft, they are at the softest setting , if there are no threads showing they are at the firmest setting. You can buy the shock spanner wrench at the dealership for around $5. Then you need a short 1 1/8" open end wrench. All I had handy was a 1" open end so I used a dremel to open it up to 1 1/8" then cut the wrench down to about 5" long.
Tom
Tom
Yeah, that's what I was gonna post. You can't compare a Honda to a Harley. Hondas are made to not feel the ride, and strictly get you from one place to the next. Harley's are made strictly to feel the ride, and possibly get you from one place to the next... eventually... if you feel like it.
