'94 nostalgia
Are you sure the battery is charged. New batteries often need to be charged. That would be my first thing to check. You could also put a volt meter on the battery when trying to start. Should be a strong 12.5 volts. If it goes lower it needs to be charged.
You also might want to check all of the battery connections for corrosion and check all of your ground connections for same.
wideglideCVO
07-09-2016 08:12 AM
hoopdog9
01-09-2013 09:33 PM
