Rocker Stage 1 - Which Fuel Management?
Hey guys - I'm finally getting around to doing the pipe, air cleaner thing on my Rocker C, and I'm wondering what you've been using for the fuel management? I know there was one guy on here that found a place to put the PCIII, but what are most of you using? The SERT? or is there room on the Rocker for the V&H Fuel Pak?
Thx
Thx
Buy the TMax Auto-tune system. Best on the market and completely replaces your stock ECU and narrow band O2's with wide band O2's and a true real time learning ECU. The difference is incredible. It makes the bike run a lot cooler. It was about 90 degrees yesterday and I could hold my hand on the valve cover going down the road.
Check out their site and read up on what this thing is capable of, including idle adjustment (mine is at 940 rpm)and rev limit (upped mine to a true 6200) along with total adjustabilty. From what I have been told, my 05 had a factory rev limit set at 5800, but the computer actually starts pulling timing at 5200. If this true, you are not only increasing rev limit, you are increasing the power output all the up to the 5800 mark and beyond to the 6200. I have yet to bounce my 07 on the rev limiter because it pulls so hard you don't need to. My 05 would bang the rev limit all the time when screaming through the gears. It aint cheap at $700, but you'll never need a dyno and you'll never have to upgrade it because it is VERY adjustable. Good luck.
http://www.thunder-max.com/
http://cgi.ebay.com/ebaymotors/ZIPPE...mZ370076935114
P.S. Make sure that you talk to TMax before ordering to confirm that they have a model for your bike. I think the site says up to 07.
