Heritage ignition problem
When I stop for fuel or a short break, I go to restart the bike and I lose all ignition lights and starter power. I always flip it into neutral and engage the clutch and wait for the pump to catch up,but all I get is a slight starter bump and its like a fuse blows. I wait about ten minutes more and tuen the switch on and off three times and the power comes back on with the clock flashing. Anyone else have this problem or have any ideals as to the cause and fix for this problem?
I'd lost all the lights(neutral,oil speedo lights etc)when I tried to start my bike couple yrs ago. It first happened when I was on coast so I wondered if salt air may have bought the problem out. I'd jiggle the switch between positions and finally would get lights and could start up. I told local HD parts guy at HD of Myrtle Beach and he told me it was probably the ignition switch. It happend several times more and I was getting paranoid about getting stranded in the middle of nowhere. When I got back home I replaced the switch and no problems ever since. You can get a Drag Specialties ignition switch for around $40. If you want a HD one with key same as your forks you have to special order it and it's around $100.
I checked the battery connections and they were a little loose and I was able to tighten them about 1/2 to 3/4 turn each.What I did find was the negative battery cable bolt head was digging into some wiring and one was close to shorting out and may even be shorting somewhat at times. I wraped the wires with elitrical tape and padded the bolt head with three strips of tape for the time being until I can get a better looking fix. Thanks guys for all the replys and help................Bloodyhead
