If you have decided to go Solo whats the point of the rear footpegs /
Can the brackets they are attached to be removed from the rear frame and are there any "blanks" ti fill the hole.
Yes they come off. with the peg in the up position twist ccw (mine came off easy). you might find a hole plug that will snap in the hole at your local hardware store.
Just taken them off ! not sure why i couldnt have figured it out for my-self.
Will need to find a chrome rod or something for the left hand side as just remembered i am installing Heartland side-plate and i think they bolt on to the footpeg shaft.
looks good without them though....cheers for the advice everyone
Just take the Heartland side plate to the local hardware store and find a stainless steel bolt that fits and use that instead. You can polish it if you like, but in any event it won't rust on you.
