relocating blinkers
This is an easy deal.You don't need any tube clamps.The threads on your stock turn signals and the fork bolts are the same size.( 1/4" x 20 I think)Just get a piece of all thread or cut the thread off a bolt approx 1 1/4" long.Screw it into the forks,put a chrome spacer over the bolt.The spacer needs to be about 1/2" long.Then just screw the turn signal housing on to the exposed bolt.Use some loctite.You'll have to cut the wires before turning the housing onto the bolt,then solder them back up.
Here you go. I am also doing this and got the chrome pieces at Ace hardware just as the original poster did. Rather than chrome bolts, I am using chrome round spacers they also have in stock.
https://www.hdforums.com/forum/softail-models/207227-turn-signal-relocation-101-with-pics.html
Fayston
Electrical/Lighting/Alarm
02-11-2023 08:02 AM
