Solo seat install
Solo seat install
I am installing a Brawler seat on my 07 Train. After scratching my head and looking at it, I think it may be easier to remove the fender to install the hardware instead of jacking the bike up and reaching in and over the tire.
I installed lowering kits, front and back a month ago, so access is pretty tight. (And contrary to what others may say, that was no day at the beach.)
Any thoughts?
Any thoughts?
Cant see why you need to remove anything! i had my o7fxstc lowered right down and have a brawler seat and i have no probs getting it on and off.What you need is a skinny mate with long arms to reach in from the back Via the rear light...(what happens if you get a flat battery you cant keep taking fender off all the time -hope this helps
You might want to put a thin film of silicone sealant on the flange that fits the bottom of the fender before putting it in with the wire or cable tie. The sealant will glue it in place and keep the nut from collecting road grime under it to grind off the paint under the fender and reduce the vibration that can chip the paint around the hole on you.
