chrome inner primary ?
hey guys im taken the inner primary off and replacing it with a chrome one, my question is do i have to remove starter or oil tank to remove it .
it has 8 bolts to remove it and we have done that but its not coming off.
the one thing that we have not done ids loosin the back tire to get pressure off the belt.
do we need to do that also?
thanks inadvance for all your input
marty
marty
Get ready for a big job. I've got the service manual here and getting to it is a pita. If memory serves you'll have to remove the rear tire and drop the swing arm. Pull the entire primary off obviously.
I've already decided to just bolt on a Kuryakin inner chrome cover when I get some spare change.
If you don't have their catalog get it! A chromers delight.
CHrome parts themselves are worthless, "Chrome covers" are even worse. Better off doing stainless steel, polished stainless steel or painted parts. CHrome though isnt durable and has countless disadvantages. If you like the "chrome" look, then go with polished parts.
You can't "Polish" chrome. And the folks who have been around long enough know that a good polished part, looks identical to chrome, and will last alot longer, and take alot more abuse, and the beauty of a polished part is when it starts to deteriorate from the elements, it can be "repolished" and restored to its original luster. When chrome pits and lifts what do you do then? LOL.
Like I said previously, if you like the "chrome" look, go with a good quality polished part. At least you will get your money's worth out of it.
ive got a manual but i put it in my work truck, and ofcourse it s where? at work'
i did notice i have to remove the starter im hoping i fdont haveto remove te oil tank and swing arm, but i probably will.
I just did the inner primary seals on my pops 01' softail and I will tell you i had the inner primary off in about 20 minutes without removing the rear wheel or the oil tank. The trick is get a good set of 3/8" extensions and a couple of 3/8" flex fittings, you might spend $30 on them but you will save alot of time. I have done this on several softails and the first one i did it the hard way(removing everthing that the manual says) the rest i have done the easy way. The hardest part is getting the rear starter bolt lined back up but it can be done .... I was in the service department the other day and saw them doing a similar service and the bike still had the rear tire and oil tank intact but the inner primary was off ....
