HD signal mirrors
HD signal mirrors
Has anybody used the HD signal mirrors successfully with removing the stock turn signals? I bought a pair last year for my Nightster, but returned them before installing. The directions said the stock signals had to remain in place for the mirrors to work correctly.
Is it possible to get rid of the stock signals (the whole point) and get the signal mirrors to function properly? if so, how?
i searched the forums and did not find a concrete answer.
thanks
thanks
I think so, unless you install load equalizer. Not just the HD one, Kuryakyn turns are the same way, remember when you add or subtract a turn signal bulb, you also change the resistance on the flasher bi-metal spring, it won't flash properly.
I installed the HD turn signal mirrors on my '98 Fatboy. I had to use a load equaliser but it was a simple install under the seat. I only wish that the mirror stalks were straight and not curved as then they would match the rest of the bike better! But they work fine and are actually better at being mirrors than the stock ones were.
