Big Bore 101-compression caps
Old 08-26-2008, 09:32 PM
Z06_Pilot's Avatar
Z06_Pilot
Z06_Pilot is offline
Default Big Bore 101-compression caps
hi folks,
OK, I know should understand all about my engine upgrades, but I am not sure about this.
what is the purpose of the compression caps on my cylinder heads? I know to depress them every time I start the motor, and that it assists in starting the engine, but why?
thanks for the info....
Old 08-26-2008, 10:06 PM
biz44's Avatar
biz44
biz44 is offline
The compression release caps you have on your heads will help with starting the engine by bleeding off some compression, so your starter motor does not have to turn over the engine while under such high compression. The more compression the harder it is to turn the crank, if its too hard to turn the engine over you could burn out your starter in a short time. You could also upgrade your started motor to a high output type. IIRC the HD version is a 1.4Kw, as opposed to the 1.2Kw stock units....but dont quote me on that.
Old 08-26-2008, 10:19 PM
Z06_Pilot's Avatar
Z06_Pilot
thx biz!
Old 08-26-2008, 10:36 PM
highbars92's Avatar
highbars92
highbars92 is offline
I have a 80" evo with 11:1 pistons and a Crane .550" cam. I added a 2.0kw starter and don't have any problems turning the motor. We didn't have to put the compression releases on it. The motor starts instantly.
Ben E
11-25-2011 06:19 AM
Qonrad
Exhaust System Topics
11-16-2011 05:25 AM
Qonrad
11-15-2011 04:35 PM
05 HD Deluxe
08-12-2007 10:21 AM
HTRAUD
01-22-2007 10:53 AM
Quick Reply: Big Bore 101-compression caps
