Shifter Sticks - Please Help
Old 08-27-2008, 07:37 AM
scaryonly's Avatar
scaryonly
scaryonly is offline
Default Shifter Sticks - Please Help
OK, so here's my problem. Whenever it gets hot, which is everyday, my shifter peg sticks when I shift. Which means when I down shift, I have to tap it up and when I shift up it needs a tap down to get back to center. I rode it to work this morning and it's only 77 degrees so it rode perfect, but I guarantee when I go to lunch it'll be sticking. I've read somewhere else that someone claims this is from using synthetic oil (which I just switched to) while others claim it's just a gunk buildup on the shifter bushings. I know the spring is still there because it does return. Any help would be greatly appreciated.
Old 08-27-2008, 07:51 AM
mke125125's Avatar
mke125125
mke125125 is offline
spray some good syn.lube into the pivot and work it in. I use rem oil on mine and it works great.
Old 08-27-2008, 12:40 PM
s2cazzo's Avatar
s2cazzo
s2cazzo is offline
1st Gear
Default Cheap plastic bushing!
I experienced the same. Cruising down the highway and after every shift, I had to tap the shifter peg back down. I was actually on my way to HD, so I when I got there, I asked them to look at it.
Simply, they just honed it out with a drill bit and re-lubed it. It has been perfect ever since.
Old 08-27-2008, 12:52 PM
scaryonly's Avatar
scaryonly
I took off the shifter, lubed it up and now it's running cleaner than ever. Thanks for the help!
Old 08-27-2008, 12:56 PM
tmitchellof PG's Avatar
tmitchellof PG
tmitchellof PG is offline
Well done. I hope all your bike problems are so easy to fix.
Tom
Old 08-27-2008, 01:31 PM
JR_HD's Avatar
JR_HD
JR_HD is offline
Remove the shifter clean it really good lube it up and reinstall. It has happend to me twice, takes about 20-30 minutes. Typically happens to me after riding in the rain for an extended period of time. In Germany, that is often..
JR
roadglidedude
05-31-2011 08:28 AM
busch
08-15-2009 06:20 PM
Evo94
01-03-2009 03:42 AM
ripto
09-18-2008 06:45 PM
fatboy5150
01-28-2008 03:51 PM
Quick Reply: Shifter Sticks - Please Help
