Cruise Control on Softail?
Have any of you installed some kind of cruise control on your softail bikes? I have an 05 Deluxe and will be doing a bit of traveling and wondered if any of the 3rd party cruise control mechanisms work well or are pretty worthless or even dangerous. Thanks in advance.
I put a full cruise control on an 06 Heritage Classic from customized cycle. Just got back from a 3,700 mile trip. The cruise worked great. At a little over $600 it is a little high priced but worth the cost to me.
It took me quite awhile to install but the system was very professionally designed. I would recommend them to anyone.
I replaced mine with a ThrottleLocker that replaces the original screw and start wheel with a new screw that has a courser thread size, so it needs less rotation to lock, and has a large wing lever that's easy to use with or without gloves. There are more than a few others out there but they usually use the stock setup just adding a lever or replacing the whole screw and star wheel with a new lever/screw setup like mine.
Here's a pic of it in the off position.
And in the on position.
Ride safe.
Look under the brake lever on your bike and there is a star wheel there called a throttle lock. Screw it in and it lock the grip at whatever setting its at once its tight. Its OK for simple stuff, but I would NOT trust it for too long as its not easy to release in a hurry. You can overpower it to shut things down if its not too tight. But like I said its not easy to use, especially if your wearing gloves.
Ride safe.
Ride safe.
A company called SAC Roadstore makes some realy nice grips with a throttle lock feature, it works great and the grips are excellent.
http://www.hotbikeweb.com/tech/0406h...rol/index.html
Ride safe.
Ride safe.
The one on my bike in the picture is the polished stainless steel version.
And yes it works very well. Just be aware that you will have to retap the hole for the new thread size.
If you have never used a tap before it might not be a bad idea to have someone who has do it for you.
If I do another either because I'm replacing the housing or for a new bike I would use a better tap to get a better thread. Doing it by hand isn't impossible, I did it, but I'm not completely satisfied with my workmanship and wish I hadn't used the drill they call for to cut out the old threads. Next time I'll use a very slightly smaller drill or maybe none at all by using a machine tap to drill it and cut the threads at the same time.
