Rear Brake Drag
Rear Brake Drag
My rear rotor gets so hot after a ride I can't touch it. My front rotor stays cool to the touch. The backing plates for the rear pads have now turned blue from the heat.
Lifting the bike there is some drag but not excessive. I've pulled the caliper twice and I see no problems whatsoever.
From what I've read the front caliper pulls the pistons back when the brake lever is released but the rear doesn't which leaves a bit of dragging.
Has anyone else had a hot rotor?
i have a 07 fxst and it does the same thing ,i noticed it when i went to put air in my back tire at the gas station and touched the rotor while putting air in the tire and burned the crap out of my hand ... my back of my pads are also blue ,i was thinking i did something wrong when i replaced the brakes because this only happened to the rear the fronts are fine
I guess I just never noticed it before.
