New guy with a couple questions...
Hi all, been lurking here a while and finally registered. Have a question regarding my '09 Night Train that I just picked up last week. My last ride was a Shovelhead. I understand about needing to rejet when installing new pipes/air cleaner with a carb but the fuel injection setup has me confused. I ordered a set of V&H pipes, an SE air filter and super tuner. The dealer says that they can install everything now but I should wait until the 1000 mile service for the dyno. They claim that the dyno is absolutely necessary to make sure fuel mixture etc. is correct. If that's the case, how can it be ok to ride it for the next 800 miles without being sure everything is OK ? I thought that during the install they programmed the tuner with all the correct specs? If this is the case, is the dyno actualy necessary? Am I in danger of destroying my engine by riding it in the meantime? If everything can be installed and set up ok now, I might as well save the $$$ ($300) that they want for the dyno. Comments/advice appreciated !
Tuner
The base mappings are close, but not exact. I have 900 miles on a 2008 FXSTC with V&H BSS, SE A/C and a Tuner module. I can tell the mix is just a bit rich by the occasional backfire and smell of the exhaust. I'll have mine Dyno'd at the breakin to get it a little closer. Just a tweak leaner, I would guess...
Rich or not, those pipes sound perfect...
Being that your pipes (V&H) and intake are very common; the dealer should have a "mapping". You should of just gone to your local MC shop and purchased a PCIII; that way you could have downloaded a map and done the entire install yourself. It would have taken 2 hours ant the most and saved you $ on the labor.
Hmm...there are quite a few dealers who install intakes & exhaust before the bike goes "out the door". Besides, its a know fact that all of the newer bikes leave the factory on the lean side.
