07 Night Train Front Tire Wear
OK, anyone tell me why the 07 NT front tire wears more on the rt side (sitting on the bike looking forward)? My first tire lasted about 6200 miles and I've got about 5000 on the replacement and its getting pretty worn on the right side again and I'll probably have to change it in the next 1000! I'm running the HD Dunlops.
Thanks,
Nighthawg
Thanks,
Nighthawg
Stock wheels ? : Inflation issue
A) What tire pressure are you running?
B) Do you check it regularly ?
Aftermarket Wheels ? : Spacing issue
A) Depending on the wheels, some aftermarket manufacturers require new (different thickness) wheel spacers
B) Some aftermarket manufacturers wheels are not as strong as stock steel wheels and the new wheel could be bent.
I got 12k out of my front, '07 fxst. It will wear more on the right because the right side of the bike is heavier. 6200 miles? Do you favor your front brake? Live in an unusually hot climate? It seems as though something is not right. I get about 7000 out of a back tire and about 12000 out of a front. And I ride kinda hard.
Thanks,
Nighthawg
Thanks,
Nighthawg
Ron
I had the same issue with my stock D402. I changed mine out around 7500 to the D407.. I have an 07 nightrain.. I did the nitrogen fill on tires for more consistent pressure supposable. Riding buddy has an 06 softail standard and his did the same with the D402 tires. Been told it could be due to lane preference too.. We'll see what happens with this new tire. And he blows through rear tires too D205..
