Clutch stays engaged on my Deluxe
1 Post
Not sure if I'm just daft, but my 07 Deluxe had a it of a fall last week. After replacing the engine guards, I decided to take it out for a ride. When I disengaged the clutch while it was in 1st gear, it wouldn't roll. I'm afraid to start it in case something has happened to my clutch and I loose control. Any suggestions? Am I doing something wrong?
1 Post
The clutch lever feels normal under my fingers. When the bike is not started, and it's in 1st gear, and when the clutch lever is in, the bike doesn't move forward or back. Neutral, of course, does. I guess I should just go back into the garage and fire it up, hold the front break in and see what happens.
Mark
I can tell you that is what I would do. Wet clutches (I believe your clutch is the wet type, please correct me if I am wrong), may feel like that after they still for a few days, or even just a few hours (they kinda get glued together), but if you put it in gear with the engine running, it will release. Your plan of holding the brake should keep you out of trouble.
1 Post
I have completed my MC Skills test today and for the past few days I've been riding on a 250 Kawi Sherpa. Pull the clutch in and it rolls easily. When I past rode my deluxe, I rolled it down my driveway in neutral, then fired it up, clutch in , first gear and away I went. Today, I think my brain is in Riceland, cause I tried rolling my deluxe out of the garage in first with clutch disengaged. No can do.
Thanks for giving my head a shake Mark!
Mark
