Any thoughts???
Any thoughts???
Posting in the softail forum to see if anyone else with a similiar machine has the same issue. In the 30 to 45 mph range when off the throttle I am experiencing bad head shake, wobble, tank slapper.....whatever your term of choice.
YES....the dealer has checked the steering head.
YES....I have been through a couple set of tires.
Every thing that dealers and mechanics have advised could cause this has been checked, rechecked or replaced.
Just wondering if anyone else is experiencing this pain in the *** sympton?
My bike is an 06 Night Train with the factory rim set up. 21 front 17 rear.
I had the same thing with my '08 Fatboy. Decel wobble beginning at the 40mph range. My indy checked for me at two different service intervals, and again (finally) when I had my tires replaced at 10k miles. Same issue on new rubber.
Finally, finally...I started reading my HD service manual and decided to do my own steering head calibration. I lifted the front-end, went through the flop measurments and started tightening my steering head bolt. It was way-loose.
Now, I can take both hands off the bars and decel from any speed without wobble.
That was MY problem. Additionally, I have read where the primary chain had too much slack and would cause a weird torque transfer. I have no experience with any of that. (Just repeating what I read on here one time).
Best of luck. Personally, I would start again at the steering-head adjustment.
Assuming this bike hasn't been in an accident, I don't care what your dealer service department says... there are only a couple of things that could cause this symptom (you can probably trust them about the tire evaluation).
P.S. Welcome to the forum
- steering head adjustment
- spoke wheel trueing
Last edited by Mr. Lucky; 09-06-2008 at 09:23 AM. Reason: noticed it is OP's 1st post
Vinish
07-20-2012 09:55 AM
midwesttom
21
06-08-2006 05:13 PM
