where do i plug in the tuner? FXCWC
Of course I removed the seat. Unfortunately, there was not a neon flashing light that said "Attach Tuner Here". I am sure that out of all the people on this forum...someone can tell me how to find the ECM and where I need to plug in the cable from the tuner. I also tried reading the instructions directly from the tuner. However, they simply stated to look in the service manual. I looked in the service manual and it says nothing about connecting a data cable.
I know that I need to install the USB cable/printer cable into a laptop and the other end into the tuner. The problem I am having is that I do not know if the tuner itself attaches directly to the ECM or if I need an additional cable (9-pin serial) to attach to the other side of the tuner and then to the ECM. If I need another cable...do I have to get it from Harley or would an office supply store have that cable as well?
Not sure if there is a comm cable connected to the ECM and tucked somewhere, but the ECM is located below and behind the oil tank. I saw it there when I had the fender off to relocate my plate. It doesn't look to be easily accessed. Hopefully someone here has some more experience and can help you.
I have an '06 Softail. Don't know if they changed anything. I'm not sure it will be the same for you. I did hear that the SERT doesn't come with cables anymore. Mine did.
First cable goes into your laptop serial port. Other end goes into the Dongle(?). Second cable comes from Dongle(?) to 4-pin Duestch connector under seat.
I bought a V&H Fuel Pack. They inlcuded instructions for the install. It wasn't easy but I did accomplish it. Maybe you can modify these to get the job done
~Drk~
http://www.fuelpakfi.com/harley1.html
~Drk~
On this site http://www.fuelpakfi.com/harley1.html click downloads, the choose Rocker. You should be able to take it from there
bdtaylor1979
12-05-2018 10:24 PM
