Somebody...talk to me...please
Somebody...need help please!
WHERE DO I CONNECT THE SE PRO RACE TUNER?
2008 FXCWC ROCKER
Of course I removed the seat. Unfortunately, there was not a neon flashing light that said "Attach Tuner Here". I am sure that out of all the people on this forum...someone can tell me how to find the ECM and where I need to plug in the cable from the tuner. I also tried reading the instructions directly from the tuner. However, they simply stated to look in the service manual. I looked in the service manual and it says nothing about connecting a data cable.
I know that I need to install the USB/printer cable into a laptop and the other end into the tuner. The problem I am having is that I do not know if the tuner itself attaches directly to the ECM or if I need an additional cable (9-pin serial) to attach to the other side of the tuner and then to the ECM. If I need another cable...do I have to get it from Harley or would an office supply store have that cable as well?
2008 FXCWC ROCKER
I will check with my stealer Monday and let you know
2008 FXCWC ROCKER
2008 FXCWC ROCKER
Hope it works out well for you. I guess your planning on copying someones tune? I let my dealer install and dyno mine. I don't trust myself enough with computers. Thats a lot of money to spend and not watch it and see the results on paper. I also heard was easy to wipe the ecm clean if your not experienced. Which would be a big ordeal. Good luck
bdtaylor1979
12-05-2018 10:24 PM
