Low Idle Issues on 2007s
I have an 07 Fat Boy with K&N filter, fuel pak, and Vance n Hines BR 2-1....i'm at 19,500 miles and starting to have problems with really low engine idle
Just started in the last 500 miles....bike will even cut out when i lay off the throttle....its cut out multiple times coasting to stop lights, etc
HOWEVER, once I get a hundred miles in and the engine is hot it seems to go away....I took it to the dealer and they pulled oil out and told me I was overfilled and that oil pressure was wrong, but it still idles low and cuts out even with correct oil
i've put in new gas from different filling stations and burned through a couple tanks so bad gas is out....
Does anybody have any suggestions on a fix?
