Just a quick little tip..
Old 09-08-2008, 04:33 PM
mplecha's Avatar
mplecha
mplecha is offline
Default Just a quick little tip..
For those of you who may want to (or need to) remove/reinstall your primary cover, Do not forget the two little seals for the inspection cover screws. I believe they're called the tower seals or something like that. I had to replace the stator in my fatboy last weekend, and neglected to reinstall those seals. I had oil leaking around the long screws on the inspection cover every time I rode it until I took it apart and replaced them. They're just two little rings that cost about $1 each from the stealer. Ah well, live and learn.
Old 09-08-2008, 06:50 PM
White-Trash's Avatar
White-Trash
White-Trash is offline
Good advice.
Old 09-09-2008, 09:50 AM
oldgeezer's Avatar
oldgeezer
oldgeezer is offline
Yep, and you normally have to put a little gasket sealer on them to keep them in place whilst buttoning up the cover. They should only be on bikes with an inspection cover though.
factorybuilt
EVO
28
07-07-2014 05:33 PM
jstorrusten
08-22-2010 10:52 PM
kelton3
05-01-2008 03:36 PM
Tiggeresq
04-08-2008 12:24 PM
rykegs
03-31-2005 12:50 AM
Quick Reply: Just a quick little tip..
