Improved front brake on the Crossbones
Are you having issues stopping?
How many miles do you have in? I know when mine was brand new the front brake was absolute sh**e. Now that its bedded in its not too bad. Sure it's not going to get the back wheel off the ground but in an emergency I too have locked it up and left a nice black mark on the road (lucky it wasn't gravel!).
Wait til its bedded in and see how you go.
All the best
Walt
All the best
Walt
I have a springer classic and when it comes to springers this is the age old dilemma. There are several threads explaining why it is that springers have a single piston brake (except CVO), the most popular being that the springer front end can't handle the braking power of a 4 piston caliper. I personally would rather tweak the springer front end than crash because I couldnt stop the bike in time.
I completely understand you wanting to change the front caliper because it was my first though as well. The front brake definitely leaves something to be desired....there are a couple of brake companies that offer aftermarket 4 piston calipers for springers....if you search through some of the springer threads you will find them.
so why are you looking for an upgraded front brake?
I have locked up the front while practicing a few times...
I like to practice panic stops and find out the braking limits of both front and rear brakes...
If your just after a bling... bling... I would think the CVO would fit
I agree, why up date a good thing. Have not had ANY problems with the braking system. 3500 miles and had a few panick stops, again no problems.
I don't see any problem with the front brake. It's black, small, and I can stop on a dime. Seriously, I do test panic stops as well, and I can't believe how quick this bike slows down. I'm a 220 lbs. dude. You have two brakes, and if used correctly, this bike stops very well.
Plus, if Ole Coyote says it works, then it works! lol
WG
WG
