Little Help Needed - Side Mount License Plate Light Wiring
I successfully mounted the plate last night on my 2008 Fatboy. I have the wiring routed to the harness area under my seat.
Does anyone know or have a picture of the License plate light wires? I need to patch in the run "power" and ground wire. Here is the link for Kuryakyn instructions; some what straight forward but not detailed enough.
http://kuryakyn.com/documents/instal...-23HD-0507.pdf
Any help would be greatly appreciated.
I just did the same last week. You can get a test light from the local auto parts store. The solid red is the power that comes on when the key is turned, the ground can connect to any of the black wires that go to the ground screw. Be sure to use locktite on the screws that mount the plate frame to the swingarm (I lost a screw).
albanynyharleyrider
02-12-2008 12:38 PM
