Slight hesitation when goosed...
Did you have it remapped when you installed the A/C? As the other poster suggested, if its a High flow A/C you have increased the AIR with out adjusting the Fuel so are running lean.
Just so you know, the IEDs or XIEDs aren't going to help when the bike is running in open loop mode. The O2 sensors only operate while in closed loop mode, which is up to 1/4 - 1/3 throttle, like the pilot jet in a carbed engin. To keep the engine runing properly above 1/4-1/3 when the air flow has been increased, you need to remap the ECU to provide more fuel to match the air intake.
You should take care of this as soon as you can, otherwise eginde damage, such as burning a valve, can occur.
If you want a fuel management system, I hear the Thundermax with Autotune is the best, but it will cost you almost as much as getting it remapped at a shop with a dyno.
You need to either have it remapped or install a fuel management system. You've increased the air flow without changing the fuel input. This leads to a real lean condition.
Yes, but in open loop it doesn't matter because the ECM commands a rich (read "safe") mixture by default. On a bike with no internal engine mods (e.g., cams or ported heads) or headers, IED/XiED is all you need. Of course, to squeeze out every last bit of performance, auto-tune or dyno tune is the only way to go.
I think you are confusing the Warmup Enrichment (WE) table with open loop. An engine warming up is indeed in open loop, and additionally uses the WE table to add additional fuel. Even though cold startup is the only time the WE table is used, it is not the only time open loop is utilized. For example, when you go WOT you are in open loop.
