floorboard extensions.
before i get flamed, i tried the search but came up with nothing. i know i saw a post somewhere, where someone used the harley goodies and the harley davidson 2" forward extensions on there fatboy. was wondering if a) if someone could post a link and b) if it is possible to do the same procedure on my crossbones. thanks
I hope they fit, I have both on order...
https://www.hdforums.com/forum/showt...ard+extensions
And these to correct brake and shifter linkage
http://doc-walt.com/waltersworkshop.htm
Yup, that's my thread.... you can do the same thing to the crossbones, but you will loose your half moon shaped boards and you will have to replace them with the HD chrome "D" shaped extended rider boards. If you don't want to loose the half moon boards, you can try getting 2 or 3 inch forward control extensions and use them to move your boards forward.
