Fuel cross over line when removing the tank question
Use a braided SS by Russell
Check this link that someone posted in another thread:
http://www.jpcycles.com/productgroup...1-F914876A749D
It's a braided Stainless Steel crossover with compression fittings, so no clamps. I saw it on a rider's bike up at the shop. Looks very sharp. He said it's been on about 2 years with no problems. Taken on and off a couple of times as well for under tank connector work.
I'm gonna do mine as soon as UPS brings it!!
There's another ss braided crossover line with the compression fittings that has a quick disconnect coupling in the center so when you need to remove your tank you pop the coupling loose & it has a fuel shut off in each end that keeps the gas from running out.
It is a higher price but solves the problem of a gas mess or draining.
Scruffie
Scruffie
