Stage one carb rejett
Hello,
I have a 2002 fatboy that is stock except for a set of Vance and Hines Straigt shots. I am going to put a K&N air cleaner assembly on it and need to know if I will need to re jett the carb. Can I put the A/C on and then check the plugs for lean issues or is there another way to know. I used to wrench on my old Mach 1 years ago but have never tampered with a CV carb. Any advice would be greatly appreciated.
Thanks
Thanks
You can sometimes get by with not rejetting if you drill the air mix plug and adjust the air down some. But, chances are you'll need slightly larger slow jet. I had a 45 and changed to a 48. Here's a link that talks about CV carbs.
http://www.harley-performance.com/index.html
I can tell you from hands on it is not hard to do if you will just search ebay for Harley Davidson Carb Jet and pic out the kit that matches your bike it is from a guy from Texas call Sorgys he has his number on it give him a call and he will send you what you need for lest then $20.00 and you will think that you have a new bike.
I can tell you I try a kit call I thin it was Thunderslide and it was a waste of money unless you get it dyno but with the jet in the carb that he will send you put it in and drive off.
http://www.sportster.org/tech/carb/r...ng-bussy.shtml
http://www.keihin-us.com/tune2.htm
http://www.jetsrus.com/main_page.htm
http://www.jetsrus.com/FAQ_rejetting.htm
http://www.keihin-us.com/tune1.htm
http://www.jpcycles.com/Tech/Articles/jettingpipes.aspx
as you can see i have been there.
