2 inch springs on Crossbones seat???
I just recieved my 2 inch springs for my crossbones seat and I have a question.
The black plastic pieces that go into the spring and slide onto the 2 posts on the bottom of the springs, well they do not lock into the 2 inch springs like they do on the original springs. Is there different pieces for the 2 inch springs ? or do I use the originals even though they dont lock the rear of the seat down.
I am going to make a couple bushings this weekend that have a better fit out of nylon to completely replace the stock black ones. Will post pics on how it turns out. (pun not intended)
I am not 100% happy with the replacement springs. The definitely cannot handle as much weight as the OEM springs, but I like the height of them. So far the rides are a little more comfortable.
Good feedback on the 2 inch springs. I was worried about the fit on the stock posts and then also about the 1 inch loss of clearance. I am 215 lbs and i do compress the stock springs when I sit on them. I was worried the 2 inchers would bottom out easily. Also, I lowered the rear end and I was wondering if the 2 inch springs would lead to my a$$ sliding off the back of the seat since the angle of the seat would be further sloped toward the rear w/ the smaller springs.
Where did you buy your 2" springs?
