Who Makes The Longest Extended Brake Pedal For FL?
Old 09-21-2008, 01:07 PM
FirstRealBike's Avatar
FirstRealBike
FirstRealBike is offline
Default Who Makes The Longest Extended Brake Pedal For FL?
Been searchin around for an extended rear brake lever. Most I have found only move the pedal forward an inch or so over stock (for an 08)... Anyone run across a longer one? I am moving the floorboards out and forward on my CrossBones (thanks Sonar Chris for inspiration) and I would like to find something 2-3" longer than stock...
Old 09-21-2008, 02:16 PM
aviator's Avatar
aviator
aviator is offline
I used the Kuryakyn E-Z Brake, #EZB-4B on my FatBoy. it moved the pedal down and forward about 1 3/4" or so. I did the extended floorboards and Harley Goodies too; all good tips from from Sonar_Chris.
Old 09-21-2008, 04:04 PM
NixonWho's Avatar
NixonWho
NixonWho is offline
You should check out Jokermachine.com or Accutronix.com. I believe both manufactures can be found in the DRAG Book too.
Old 09-21-2008, 10:27 PM
sonar_chris's Avatar
sonar_chris
sonar_chris is offline
First of all thanks for the nice words guys.
I used the HD extended lever and havent had one problem. Put the pedel in a much more user freindly postion. Although, if I had to do it again, I would probably go with the EZ break lever, and get one extended shifter arm for the front.
Old 09-21-2008, 10:57 PM
FirstRealBike
Thanks for the replies
I already ordered an extended shifter from Walters. I will probably order their brake arm too, but I was kinda hoping to find one a bit longer. I've got the Harley Goodies and the HD forward rider pans which are off at the powdercoaters as we speak... Lookin "forward" to installing this stuff!
http://www.waltersworkshop.com/exten...ft-levers.html
http://harleygoodies.com/
http://accessories.harley-davidson.c...t/default.aspx
Old 09-22-2008, 11:45 AM
CrawdadAZ's Avatar
CrawdadAZ
CrawdadAZ is offline
Here's another option......... (link below) I have this along with their extended (forward) floorboards.
http://www.bubbasbrake.com/xcart/pro...cat=251&page=1
FenderGuy53
10-29-2011 06:41 PM
Talldog
09-26-2011 03:16 PM
leadman
04-17-2010 08:10 AM
dshukwit
11-01-2008 08:48 PM
CSI
06-14-2007 05:44 PM
Quick Reply: Who Makes The Longest Extended Brake Pedal For FL?
