dented oil filter
dented oil filter
so yesterday i changed the oil in the bike. after riding around the block there was still an oil trail from the under the filter. so i took my filter wrench and wanted to see if i could just get a little turn out of it. instead i put 2 small dents around the grip part of the filter. i think im gonna change the filter but have any of you ran a filter with dents?
Was the reason for changing the filter a drip or trail, or did it show up after the filter change out? I'll base my response on the latter: I think you are torquing your filter too much esp. iy you leave dents in the can! By all means buy a new filter (cheap enough), fill some oil in the filter prior to install (will prevent cavitation), and with little run-out at top from this, lubricate the oil ring on the filter. Thread the filter by hand onto the mount until you cannot turn anymore (don't gorilla torque it!), then using your filter wrench, turn another 1/4 turn. I'm too lazy to get up & get my manual to see what the exact HD procedure is but I've been doing this since I was 19-yr old and have never had it go wrong! Good luck with it!
thats what i did. and only changing filter beacuse of an oil change. tightend the filter by hand as far as i could then rode it. once i was back i noticed the oil(prob was just from the oil change) but i used the wrench slightly. i will change out the filter but not use the wrench this time
jpnelson1978
Oil Archive (no new posts)
07-24-2006 06:28 PM
