Do all Softail fenders mount the same using the same hardware? Can I mount a rear fender for FL, FLHX on my 09 crossbones using stock hardware without cutting or drilling, as long as the fender will fit the 200mm rear tire?
if you'll check some of the other posts - you'll see where guys have swapped the FatBoy fender for their 'Bones...... I'm sure a PM will get you the info you seek.
I'm not sure the FLHX fender will fit, I believe it runs a 180 rear tire.
