Oven Cleaner Damage to my Engine ..
Hi All,
I have read a few threads here about Oven Cleaner Damage, it seems there is one Polish that worked well with one fellow here but his Engine was Aluminum shining Evo.
I have the TC88 Silver Finish which has some ugly spots now.
I have a few questions..
1 - What is the cost/labour of taking the whole Engine off, grinding it, and powder coat ? .. how much would a shop charge ? maybe I should just do it when I plan to put big bore kit next year ?.
2 - Would using ScotchBrite help ? or would it do more harm ?.
3 - If I use ScotchBrite ? do I need to buy a clear coat spray or something to protect the Engine ? I imagine I will remove some of the factory finish .
I know now the right way to use an oven cleaner on my chrome pipes , expensive lesson , but I appreciate your help to make the engine look at least better until I have cash/time to take it out and finish it properly.
Regards
Regards
Scothbrite will get rid of your spots, but it will make it look dull in the area you used it, you'll have to decide which is the lesser of two evils on that one. As far as pulling the motor out, unless you have experience or have a buddy with some I'd stay away from it. It's not pulling it that's hard it's just knowing what to do when you put humpty together again. You could always go with the hi-temp enginge paint, I've heard of a few guys on here that's done it, and I've seen pics.....looks pretty good, then when you have money get it powdercoated.
Ok,
My local store does not have any scotch brite, now since I am 'new' to this I would like to know more details.
Here is my guess and correct me if I am wrong.
1 - I am getting a 'sander polishers' tool < any recommended speeds ?>
2 - What type of surface do I need to work on the engine ?.. certain 'grit' I believe ?
3 - When I am done scrubbing the bad spots I finish it by spraying a clear coat .
Am I correct ? all input is welcome
Regards
Regards
Ok,
Regards
Regards
You could try wheel acid in a small inconspicuous area and see what that may do for you (cold motor). Again available at auto body supply shops and places that sell aluminum mag wheel cleaner.
Just my 2 cents.
I would be VERY careful of sanders and polishers unless you are experienced. 3M scotch pads are available at any auto body supply store. They are available in different grads of coarseness Maroon,gray, white, gold etc...
Just my 2 cents.
Just my 2 cents.
I have replaced my Cam cover with a chromed one, so I will grab the bad cover and take it home and see if I can fix it.
If anybody else has any ideas, I am all ears.
Hi All,
Regards
Regards
RJ
