How do u install the solo seat on Rocker C
I picked up my solo rocker seat to install on my Rocker C. and i can' figure out how thing goes on. I spoke with the parts guy at the stealer and he said to remove all the original hardware from my bike and just install the solo seat. But it makes no sense how to install the solo seat after I removed everything from my Rocker C. Please help!!! I've seen a few people on here with the solo seat installed and I'm wondering how they/you did it. Please let me know what I'm missing.
1)Flip up seat and remove small screws (at the base of the tank).
2)Use a large torx ratchet to remove the chrome brackets for the C seat.
3)remove one side at a time when taking off the flip seat portion (carefully - it's 3 pieces)
4)Remove small pan held in place by 4 small screws/ bolts (located just underneath/ alongside of the black plastic battery cover).
5)Using the same 4 screws/ bolts, install the solo seat pan/ bracket (part #51886-08)
6)Place the metal tab at the front of the seat underneath the tank (in the slot). You may have to push it firmly in to line up the two pins that go into the pan #51886-08. FInish off by covering the holes form the brackets with the frame cap covers (painted to match from HD - Crimson part #71696-08, not sure which the black part number is).
That's it... you're ready to ride.
Hope this helps you out. I like the solo seat (big improvement over the OEM C seat) but it still feels as if my rear end wants to slide off the bike when I accelerate. Probably going to rework the foam a bit.
https://www.hdforums.com/forum/softail-models/264381-fxcw-seat-on-rockerc-caps-on.html
I didn't take pics, but it's quite simple. Here's my memory of how it goes...
one more step though, take the rubber grommets from the original plastic seat "pan" and transfer them to the new metal seat pan.
this is one of the easiest mods to do.
did you actually get the seat pan for the solo seat? if not, there is your problem.
DOH, you're right - I totally forgot about the grommets. It's pretty much all common sense. (once you have the right parts, of course). The hardest part was getting the right size torx for the chrome pillion bracket. I believe that they're put on with crazy glue as they were quite hard to loosen. LOL
