Is there a way to disable the auto cancelling turn signals? Mine always cancel out on their own before I want them to. I don't want 'em to turn off until I says so! For example, I'll hit my signal as I approach an intersection to make a left turn. By the time I come to a stop, they'll cancel out and the cars behind me are honkin' their horns wondering, "why are you stopped, the lights green, GO!!!"
Turn signals cancellation works from the signal from the VSS to the TSM/TSSM based on speed and distance once the turn switch is closed; the slower you go the less distance it stays on. I'd rather someone honked at me then I got hit by some dumba$$ because I forgot to cancel my turn signal. Just turn and give them a Chuck Norris look!
I have the opposite problem. They only auto cancel when it is over about 80 degrees. Since I'm in Michigan, most of the time they don't cancel.
I am clueless as to why they would be temperature sensitive.
