"DYNO" Numbers For SOFTAILS
Old 10-29-2015, 03:05 PM
c_marino's Avatar
c_marino
c_marino is offline
06 FXSTB - 88Ci EFI- Stock displacement/Stock heads
HQ-0034 Cam
Knock off big radius exhaust
DNA air cleaner
PCIII
91 hp /91 tq tuned by Rick Stetson
  #1192
Old 10-30-2015, 06:08 PM
madjeeper's Avatar
madjeeper
madjeeper is offline
Default After my upgrade
Just did a top end 103 build on my 2008 FLSTC. Ported polished and CNC heads to 10. to 1. Flat top S&S pistons. Bla, Bla, Bla. And for the cam I went with a Chris Rivas ez start 584. I have a SERT tuner. This was the right cam for my wants, FAST and a lot of TORQUE!!!
I went from a SE204 96" to this.
The before is a down load, good guess too! Then the finale. The cam is a hipper one for sure!
Attached Thumbnails "DYNO" Numbers For SOFTAILS-dyno-chart-after-103-build-10-15.jpg
  #1193
Old 11-05-2015, 02:16 AM
brawner11's Avatar
brawner11
brawner11 is offline
97" S&S
TW6 cams
Stock Heads
10:5-1 compression
  #1194
Old 11-05-2015, 06:09 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,792 Likes on 3,303 Posts
Nice numbers........enjoy...
  #1195
Old 11-05-2015, 01:16 PM
NeilMcA's Avatar
NeilMcA
NeilMcA is offline
Very good numbers and excellent ratios for a 96" those woods cams seem to be the best about. What bike is it on?
  #1196
Old 11-05-2015, 05:24 PM
98hotrodfatboy
I must say, I am partial to Woods cams myself....
  #1197
Old 11-21-2015, 07:07 PM
Bertrum's Avatar
Bertrum
Bertrum is offline
4th Gear
I got 117 hp 118 ftlb torque i have a 103" heads are done,cams,hpi throttle body, ss dual intake, v&h pipes.
  #1198
Old 11-22-2015, 07:47 AM
NeilMcA's Avatar
NeilMcA
NeilMcA is offline
Your torque to cubic inch ratio is really good. 1.145!!!
The ultima el Bruto 113ci gets 120 lbs/ft and thats the most powerful crate engine ratios around so yours are excellent
  #1199
Old 11-22-2015, 08:58 AM
98hotrodfatboy
That is one very nice torque curve. What cams are in that?
  #1200
Old 11-22-2015, 12:12 PM
txphatboy's Avatar
txphatboy
txphatboy is offline
Posted this sheet in another thread, but not in the Dyno thread. Sheet shows difference between the old Tw6g cams on a 95" with worked heads and larger valves compared to the current HQ39g cams with worked heads and stock valve size. had been been trying all kinds of exhausts trying to improve low end power and finally decided to try another set of heads. Not sure how the tw6 cams would have run with the new heads, but was not willing to pay another $400 tune if I wanted to try the HQ39's later, so I just installed the 39's. Nice improvement in low end torque - kind of surprised me since I dropped compression from 10.5:1 to 10.1 when installing the new heads. The yellow hashed areas are improvements with the new heads and 39's.
Quick Reply: "DYNO" Numbers For SOFTAILS
