why is the SERT so much beter.. stealer says popping is possible with the stage 1 because of the big radius.. i plan on using the heavy breather. all rockers running strong with this set up?
Ive got the SERT,Radius,and Screamin Eagle air breather and my Rocker pulls hard. Im lovin it so far but will eventually do the 103 kit in the near future.
I have the Screaming Eagle air cleaner, Stage 1 download and V&H Short Shot Staggereds. There's no popping or issues at all. It runs strong and has a lot of torque.
my local dealer doesnt have a dyno.. but claim they can get it close. i just hope i will be using the tuner to its best. if not ill have to bring it somewere else. what are your hp. numbers wiith those set ups..
Once your engine is breathing it's going to need to do a better job at providing a stable fuel mixture. Your carburetor or EFI will need to be corrected to compensate for how differently the engine now breaths. Fuel injected models use a preprogrammed map to instruct how much fuel is to be delivered. Since you have changed the way the engine breaths, those instructions may not supply the proper stable fuel mixture under all conditions. Granted your bike will still run, but the only way you are going to get the most out of your EFI bike is to have it remapped.
right.. i understand the theory. my question..is the dealer going to be able to make the most power without a dino? excuse my ignorance as iam new to this sort.
