twin cam primary chain adjustment
Old 10-06-2008, 11:31 AM
rcc's Avatar
rcc
rcc is offline
What he said. Just leave the socket and extension on the nut and lift it up.
Ron
Old 10-06-2008, 11:46 AM
128auto's Avatar
128auto
128auto is offline
People are confused here, when the chain guide drops, you have to pull the guide out a bit to move it up, the back wedges are binding, make it really difficult to pull up. Even you leave the socket and extension attached, it is still hard. What I do is using a coat hanger, make a little hook at the end, pull the bottom of the chain guide while loosening, make your life a lot easier.
Old 10-06-2008, 05:24 PM
lowperformance2's Avatar
lowperformance2
lowperformance2 is offline
i got it everyone thanks, anyone have INFO ON CHANGEING THE IOL AND TRANS FLUID?
Old 10-06-2008, 06:56 PM
anubisss's Avatar
anubisss
anubisss is offline
It's all in the manual. Best $60 you'll ever spend...
Old 10-06-2008, 07:03 PM
128auto's Avatar
128auto
128auto is offline
Put it this way, you need it sooner or later.
Old 10-06-2008, 07:19 PM
anubisss's Avatar
anubisss
anubisss is offline
Back in the day, you had to ahve a manual before others would let you become a hang around.
Old 10-06-2008, 07:24 PM
128auto's Avatar
128auto
128auto is offline
Lmao :d
Originally Posted by anubisss
back in the day, you had to ahve a manual before others would let you become a hang around.
Old 10-07-2008, 05:51 AM
lowperformance2
i dont have a book and i ordered it but it is not here and i need to change the oil today..
Old 10-07-2008, 07:45 AM
cwsharp's Avatar
cwsharp
cwsharp is offline
I think, on occasion, that it is a good idea to take the primary cover off and do a thorough inspection while checking the chain tension. Now, if you have an automatic chain tensioner, the time between checking is long enough that it wouldn't hurt to do that every time. Check to make sure that the stator bolts are tight while you are at it. I recently heard that some went out of the factory with the wrong loctite on them. I'm going to do this inspection before I head for Biketoberfest, that's for sure.
You should be able to just try to rock the stator to see if it's loose in the rotor. High pitch whines have been associated with this problem, just before the stator exploded in the primary case (this is all hearsay on my part... I haven't seen it happen). Note that if you take your stator out of the rotor for cleaning, etc. you should use new screws and use permanent threadlocker to reinstall it.
Old 10-07-2008, 08:44 AM
deluxenut's Avatar
deluxenut
deluxenut is offline
Take a look here: http://www.dudeworld.com.au/HOWTO.GEARBOX.HTML
Iarecobra
06-25-2014 12:28 AM
Nuday
04-22-2013 08:10 AM
AzDon
04-24-2007 08:15 AM
veeman129
04-05-2007 07:07 PM
03 Softail
01-30-2006 07:39 AM
Quick Reply: twin cam primary chain adjustment
