FXSTB steering nut size
Old 10-05-2008, 11:16 AM
Aaron01's Avatar
Aaron01
Aaron01 is offline
Default FXSTB steering nut size
Since I have a vibe on the front of my Train at about 40-50 mph I want to check the play in the steering neck bearing as the dealer said they did it at my 10,000 service but I have my doubts. I took the cover off and the nut is bigger than any wrench or socket that I have so does anybody know what size it is so I can try to get the correct size?
Thanks,
Aaron
Old 10-05-2008, 12:17 PM
128auto's Avatar
128auto
128auto is offline
Just measure across the flats of the nut and you will find the size. You should follow the manual to do head bearing adjustment, it is critical.
Old 10-05-2008, 12:41 PM
DECON BLUE's Avatar
DECON BLUE
DECON BLUE is offline
There is a lot more to it than just tightening the nut, you should get a service book.
Attached Thumbnails FXSTB steering nut size-100_0577.jpg   FXSTB steering nut size-100_0585.jpg   FXSTB steering nut size-100_0586.jpg   FXSTB steering nut size-100_0589.jpg
Old 10-05-2008, 12:47 PM
bigoscycles's Avatar
bigoscycles
bigoscycles is offline
If you tighten it to tight it will have a catch in it. The bearings may need to be packed. I think the size is 1 1/4.
Old 10-05-2008, 01:49 PM
monkyman's Avatar
monkyman
monkyman is offline
It is 1 1/4, I had to tighten mine this year.
Old 10-05-2008, 05:47 PM
Aaron01's Avatar
Aaron01
Aaron01 is offline
Thanks, 1 1/4" it is then. I already have a service manual and know how to do the procedure, I just wanted to have the correct size tool on hand when I start.
nkauf21
01-18-2012 03:45 PM
kmealp
07-31-2011 07:14 AM
davidc
04-19-2009 06:43 PM
Shizims
03-26-2009 08:48 AM
hdvespa
09-02-2008 10:27 AM
Quick Reply: FXSTB steering nut size
