07 stock pulley?
70th some have said it will work. I don't think it will myself as there isn't enough room to adjust on the axle adjusters and you also would have to change the primary belt. That makes it a bigger job now.
65 tooth might work... but you would change your gearing. I still don't think it will as not enough adjustment in the axle adjusters. Could be wrong though.
DNA makes a 66th replacement and I know Dinger got his from hogpro in a 66th.
By the way, it's 1" not 1 1/8".
Yeah I changed my 07 pulley which was a 66 to an aftermarket pulley that matched the wheels, it was a 65 tooth. It left me barely any room for adjustment out the back of the adjuster. And ended up binding on the brake caliper. After about 2 months of belt tension issues went back to the 66.
Measure the belt.....
But I know for sure it's a 1"....
DNA's 66th sprocket is only in a 1 1/8". How do I know this for sure? I am running one on my 07 Heritage. It will work. Your only talking an 1/8 of inch.
Look at Dingers bike, he as a 66th on his I believe in a 1"... which also works.
