Rear Brake pedal removal.
10-15-2008, 03:18 PM
Is this an easy job. Want to send in to powdercoater, removed shifter lever no problem.
08 Night Train.
Thanks.
10-15-2008, 03:49 PM
Yes very easy. Remove cotter pin, and the small washer. Push the pin out and remove the brake pedal. Reverse the procedure to install, BUT use a new cotter pin.
10-15-2008, 03:51 PM
Placing a sticker properly aligned is as easier as it gets other than that...
You shouln't have any problems. Just dont break the nut lock (twisted metal wire if you don't have a replacement).
Mimo.
10-15-2008, 07:03 PM
Do put Loctite blue on the threads.
MeanieNJ
Powdercoat & Paint
07-07-2014 11:26 AM
OV-10
04-03-2011 06:23 PM
ChromeJunkie
12-14-2008 06:50 PM
Kolni
07-05-2007 05:42 PM
dlkeneipp
12-10-2005 12:39 AM
2004 ,
brake ,
cb750 ,
crossbones ,
davidson ,
fatboy ,
harley ,
honda ,
lever ,
night ,
pedal ,
rear ,
removal ,
removing ,
softail ,
train
