08 Deluxe passenger foot support
passenger footboard
I doubt whether you will have any luck finding anything adjustible using the stock foot board bracket on the right side of the scoot. It mounts to the exhaust bracket and is different than the left side which is identical with what is found on a Heritage left side. If you change exhaust to a true dual, the exhaust bracket can be removed and a new two piece bracket which bolts to the frame like the left side can be installed. If you get to this point, you may be able to find a standard type after market bracket that is adjustable upwards. There might be an easier cheaper fix that will work, but I am unaware of it.
Deluxechuck
01-02-2009 09:10 PM
