Has anyone out there re-located the front turn signals on a Rocker from the bars to the forks and if so how did you do it. The Rocker has 49MM forks and I can't find anything other than a Kuryakyn bracket but then I would have to use Kuryakyn lamps. I just want to move the stock blinkers from under the bars to the forks. Thanks for any help.
here is what mine look like. you can actually get harley made brackets. i forget for which model they were though (they might be for a fat boy), but they do work on the rocker.
RockerDave do you have pics of the signals mounted to your bike using part #69433-08.
Nope...I haven't relocated mine yet (will be doing it during the winter).
However, if you look at Alain's pic above, he used the same ones.
I actually purchased the 68952-98 only to find out that they
did not fit on 49mm forks.
69433-08 are the same ones for the 08 Dyna models (08 and later Dynas have 49mm forks).
click this link to check them out: http://www.shopbluespringsharley-dav...ation-kit.aspx
Here is what I did. Lights are from Joker and brackets are HD. The light were made to fit on hanlde bars but with a little mod made them work on fork tubes.
